allison transmission to Dodge Cummins
Old 08-04-2011, 10:30 PM
mr_GDR's Avatar
Default allison transmission to Dodge Cummins
what would be the best allison transmission, to put in my 2007 5.9 4x4 Dodge cummins truck? where could I get a trans? and the Adapter kit for it?
thanks
Old 08-07-2011, 04:50 PM
turbo20psi's Avatar
Why? 48RE is pretty strong and cheaper to upgrade then the Allison.
http://www.goerend.com/internalparts.php
Old 08-07-2011, 06:12 PM
skinnysfd's Avatar
Old 08-10-2011, 03:04 PM
98cummins12's Avatar
Build yourself a HD 48re and itll be stronger then an allison any day. Allisons are only tough when the truck is stock. Once you mod those duramaxs the allisons dont hold up after 500hp.
Old 08-11-2011, 02:13 PM
1989w250's Avatar
Yeah my bud has gonr through 3 of em
Old 08-15-2011, 08:47 PM
kdafire's Avatar
The Allison is a great trans but your right anything much over 100hp from stock it starts to break the tanny down. if you are really set on the allison you can put an upgrade kit on it to withstand much more HP it just all depends on what you want to do with it.
Old 08-16-2011, 11:11 AM
vcustoms86's Avatar
Agreed. The last i knew, the only way to put a allison with a cummins is to build ur own computer for it. Has someone come out with a computer to control the allison/cummins combo?
Old 08-21-2011, 06:56 PM
johnyb59's Avatar
Default Re: allison transmission to Dodge Cummins
Fleece performance and destroked have kits and controllers to do the swap.
Old 08-21-2011, 09:37 PM
twinturboedcummins's Avatar
Default hello
my truck is running a ford 5r110w mated to a 12v cummins using a destroked kit and a pcs trans controller
Old 08-23-2011, 12:01 AM
torqctd's Avatar
Waste of time and money to put an Allison in a Dodge.......just build up the 48RE and it will out preform the Allison anyway.
Quick Reply: allison transmission to Dodge Cummins
