Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
vin locked on my 1856 super chips tuner! how do i fix this?
Old 08-09-2011, 05:34 PM
Canadianf350's Avatar
Default vin locked on my 1856 super chips tuner! how do i fix this?
i just bought a 2008 f 350 crew with the 6.4. the dealer i bought it from took the dpf/cat delete pipes off for cert. and left the tuner in the console. i want to run the delete pipes for better mpg reasons.. is there anyway to fix the issue? it says "tuner is vin locked. tuner 4 is installed"
can i still use it since "level 4" is installed?
Last edited by Canadianf350; 08-09-2011 at 05:34 PM. Reason: Automerged Doublepost
Old 08-09-2011, 06:12 PM
Red_Rattler's Avatar
High Tech Redneck
Soooo they put a tune on the truck for you? Or you left the tune on the truck and they flashed it? Im kinda lost here as to what happened
Old 08-09-2011, 07:25 PM
im not very knowledgable about this stuff but im pretty sure the dealer put the stock tune back on the truck
Old 08-09-2011, 07:47 PM
High Tech Redneck
so you bought the tuck with the tuner in the console of the truck and it says vin locked, right? Also they removed all that stuff for cert? Whats cert? Is the dpf and cat back on the truck now? Im willing to bet the guy traded it in with a tune on it and the truck was reflashed at the dealer without taking the program out first, sooo now the programer is useless
Old 08-09-2011, 08:01 PM
no the tuner wasnt physically inserted into the port and the truck dealer i bought the truck from sent it to a ford dealer to get it certified... before the truck went to the ford dealer it had the dpf/cat delete pipe on and for the cert. (safety) they installed the stock pipe back on (dpf and cat).
another question.. it says its locked however it says level 4 installed.
will it still work?
Last edited by Canadianf350; 08-09-2011 at 08:01 PM. Reason: Automerged Doublepost
Old 08-09-2011, 08:06 PM
High Tech Redneck
that was the last setting the tuner was on.... They flashed the computer making it back to stock and now the programer is a paper weight
Old 08-09-2011, 08:22 PM
is there any other tuner or programer that you guys recommend? i heard the spartan was highly ranked..
Old 08-09-2011, 08:48 PM
High Tech Redneck
def spartan and take the dpf back off
Old 08-10-2011, 09:06 AM
I'd go Kem or Innovative myself. Spartan seemed to fall off the map a bit lately and I've read a lot about their transmission shifting lacking compared to the others now.
