turbo upgrade on 6.7
Old 09-13-2011, 10:54 AM
johnnyb1's Avatar
Default turbo upgrade on 6.7
i have a 07.5 dodge qcsb 6 speed manual. i wouldnt mind going with a bigger turbo but still small enough to keep from a lot of spool lag. but i dont want to loose my exhaust brake is there any way of keeping my exhaust brake with a aftermarket turbo?
Old 09-13-2011, 01:32 PM
coors_man_2005's Avatar
im running a silver 66 i lost my e brake but it runs awsome u could always add a pac brake if u really want one but there are a couple companys that have the modded turbo for the 6.7i thinks its better to get away from that vgt turbo my opinion
Old 09-13-2011, 01:53 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
industrial makes a bigger vgt turbo. i have sold a few. they work good but if you are going to run high boost they still will run high drive pressure. i like my vgt with the exhaust brake but i keep the boost down. i got to have the exhaust brake towing. it depends on how you use the truck.
Old 09-13-2011, 06:27 PM
dodgeram082500's Avatar
with you having a manual i wouldnt go any smaller than a 66/74/14 however the only way of keeping the e-brake is buying an aftermarket brake. My suggestion forget it ever had a e-brake put a 66 on it and have lots of fun. you can also spool that turbo on a stock fuel system with very little if any lag
Old 09-13-2011, 08:26 PM
johnnyb1's Avatar
Will i have to change my manifold or will i be fine with my stock manifold
Old 09-13-2011, 08:30 PM
I'd recommend a Industrial Injection Thunder 330 Turbo.
Old 09-13-2011, 09:43 PM
brk126's Avatar
im runnin a 62/80/14 and love it
Old 09-13-2011, 11:11 PM
04.5-07 manifold and everything is pretty much bolt and go
CCC1971
6.7L Performance
11-20-2017 04:49 PM
Cdog121
11-16-2015 01:49 PM
BIGRED12V
16
01-03-2015 07:47 PM
brown2294
11-03-2014 10:09 PM
strokin97
09-30-2014 11:59 PM
Quick Reply: turbo upgrade on 6.7
