Transmission Problem
Old 09-19-2011, 03:47 PM
red dually's Avatar
Default Transmission Problem
I have a 2005 duramax with an allison transmission at take off or after letting off of the throttle and reapplying the throtlle I have alittle play in the transmission. Does anyone have any suggestions what it might be or know a good transmission shop for allisons in the Winchester, VA area or around there.
Old 09-19-2011, 08:42 PM
2500HeavyDuty's Avatar
how many miles are on the truck, how is the fluid level and when was the last time you swapped the filters
Old 09-19-2011, 08:56 PM
red dually's Avatar
The truck has around 84,000 and the fluid level is good but it has ben awhile since I changed the filter.
Old 09-19-2011, 09:16 PM
BriteWhiteRam's Avatar
I change the filter with every oil change
Sounds like you might have some shift flare or a sloppy tq converter
Old 09-20-2011, 03:45 PM
there is also an internal filter, sometimes it can wiggle around causing a small vacum leak on accel and decel
Old 09-25-2011, 08:28 PM
red dually's Avatar
Brite White Ram is there a way to tell for sure that is is the tq converter and if it is the converter what is the best way to fix it replace it?
Old 09-26-2011, 05:07 PM
a good scan tool can can do that for you. some one with a tech 2, snapon scan tool , or efi live.
Old 09-27-2011, 10:27 AM
red dually's Avatar
2500 Heavy Duty my truck isnt showint any trouble codes so if there isnt any codes showing how or what will the scanner pick up.
Old 09-27-2011, 11:58 AM
i mean to measure tcc slip to see if the torque convertor is your problem. but i doubt it
burndiesel
10
02-07-2023 01:15 AM
jeremy01995
09-14-2015 06:34 PM
Max713
04-17-2015 01:18 AM
02Stain
02-17-2015 10:21 PM
TheDirtyDozen
10-01-2014 10:09 AM
Quick Reply: Transmission Problem
