Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
02 excursion 7.3 diesel interior heater problems
Old 09-24-2011, 07:59 PM
almostamillionkilometers's Avatar
Default 02 excursion 7.3 diesel interior heater problems
Lately my interior heater is only working on the dash. No matter where I position it it only stays there. I have heard that it could be a vacuum line but I am having a hard time locating this line. Does anyone have any ideas or has it happened to someone else. Much Thanks
My Betsy has 895,000 kilometers on her and I am hoping she will hit a million Kilometers.
Old 09-27-2011, 02:43 PM
CSIPSD's Avatar
Check the vacumm pump when you first turn the truck on, before you start it you should hear it running under the hood on the passanger side.
Then check both the lines that run down to the front hubs, you will see them right next too the brake lines.
Old 10-02-2011, 07:24 AM
njneer1's Avatar
That's exactly what it was with mine......replaced both of my lines to the hubs a few years back for the same symtoms
Old 10-06-2011, 10:53 PM
Thanks for all your help. I replaced the vacuum pump @ $182.00 Cnd and all is working well.
KimberlysTruck
Ford Powerstroke 99-03 7.3L
03-05-2015 06:28 PM
Pike
01-25-2015 10:38 PM
krinderhagen
12-31-2014 07:12 PM
Baconjosh
8
12-11-2014 03:16 PM
Quick Reply: 02 excursion 7.3 diesel interior heater problems
