97 7.3 runs rough
Without a scanner, it's going to be a tough thing to diagnose.
You need to get it running and check fuel pressure... Also, before you start it, check the oil level in the HPOP reservoir. Then after it dies, check it again. Make sure your oil level in the crankcase is full.
If all those are in good shape, It could be uvch's or injectors...
bdbfam
08-31-2015 09:06 PM
UniqueCopy
12-14-2014 11:37 AM
