P003A Code / Bad MPG maybe linked
Old 10-17-2011, 09:00 PM
dieselgooroo's Avatar
Default P003A Code / Bad MPG maybe linked
I have my first major problem out of my Dmax. The CEL came on over the weekend. The main code i pulled was the P003A. I took it to a dealer that I knew dealt with Dmaxs alot after talking to the tech. I was pretty sure i need to rebuild or upgrade my turbo. He did say he could run a few checks to make sure it was the vane stuck. This ended up costing me $65+tax. So i was pretty happy to pay that little and be sure what the problem was. In the end he came back said yes your vane in the turbo is stuck and i was going to need to rebuild it or upgrade it. So i called Fleece performance the tech there told me he would be able to rebuild it for alot cheaper and that i don't need a upgrade unless i was looking for 500+ HP so I went with the rebuild. I haven't sent it off yet or fixed it. I just started this today, I just wanted to let everyone know about this problem.
After this has happened I have kinda looked back on the way my truck was running. the major signs i seen was bad mpg. (to be confirmed after fix) Aslo when my truck was at a idle it always changed sounds (kinda like the A/C compressor was kicking on/off. I assumed it was a normal sound out of the Dmax. But it may look like it was this vane the hole time.
If anyone has thought please let me know.
bbilt
5.9L Rotary Performance
05-29-2015 07:05 PM
Smokin Joe
03-29-2015 12:18 PM
Quick Reply: P003A Code / Bad MPG maybe linked
