1999 7.3 no wts no glow plugs working
Old 10-25-2011, 12:38 PM
hoss74's Avatar
Default 1999 7.3 no wts no glow plugs working
all fuses good changed gpr put used pcm in it nothing helped. any ideas would be appreciated
Old 10-25-2011, 02:59 PM
jmac5058's Avatar
Welcome,how do you know their not working? Is the wait light not working?
Old 10-25-2011, 03:41 PM
hoss74's Avatar
wts doesnt work cant hear the cycle also have no voltage to fuel pump could it be idm
Old 10-25-2011, 05:00 PM
95powersmoker's Avatar
Check your fuses... I bet the fuel bowl heater shorted out and blew that fuse which also controls PCM...
Old 10-25-2011, 06:11 PM
hoss74's Avatar
all fuses are good
Old 10-25-2011, 07:02 PM
Originally Posted by hoss74
all fuses are good
double check them... Don't just look at them and say ah ya it's good. I've seen bad fuses look ok... Underhood fuses too...
Old 10-25-2011, 07:17 PM
fordornothing's Avatar
ren a continuity test on them...
Old 10-25-2011, 07:24 PM
Check Fuse #30 under the dash... That's where my money is at...
Also unplug the fuel bowl heater...
Old 10-26-2011, 08:11 PM
bowietrucking's Avatar
my 95 did this years ago heading to the races, it was a big fuse under the hood. fuel heater element i believe is what it was called. dam thing kept blowing fuses when i'd turn the ignition on. dang, that was expensive til i figured out what wire to unplug so i could get to the dang racetrack!!!
Metz1234
03-03-2016 10:20 PM
rkp209
Chevy/GMC Duramax 2011 LML
01-10-2016 10:32 AM
Toms73
03-23-2015 08:31 PM
Texasthb
03-04-2015 08:20 AM
Baconjosh
8
12-11-2014 03:16 PM
Quick Reply: 1999 7.3 no wts no glow plugs working
