4Wheel drive problem
Old 11-12-2011, 02:19 PM
farm boy's Avatar
Default 4Wheel drive problem
I have a friend with a 2000 F350 and he is having a problem with the four wheel drive it goes in just fine but once it is in it doesn't want to disengage at all. are there any ideas of what it may be.
Old 11-14-2011, 08:08 AM
bowietrucking's Avatar
try backing up a little, but also you have to back STRAIGHT up. dont ask me why, but mine is a pain in the *** at times to get it out of 4x4 also. if you find something else, please let us know...
Old 11-15-2011, 09:39 PM
OceanDiesel's Avatar
My E99 is that way too. Back straight up or it just won't let go.
Old 11-16-2011, 01:10 PM
yeah, i found out the hard way the very 1st time i locked in my hubs on my 01. i was in vermont, left to come back to pa and the dang thing felt like the front end was riding rough. little did i know, with the hubs locked out and the switch in the 2 wheel drive postion, the hubs never unlocked! guess i never really had to back up the whole way home, so it made sense! live and learn, right?
Old 11-16-2011, 02:35 PM
farm boy's Avatar
The transfer case that he has in his truck is electrical shift in and out and when we put it in it goes in just fine with lockin the hubs in and when you take them out and back up the hubs release but the t case doesnt shift out when you switch it out.
Old 11-16-2011, 04:12 PM
wmorrispilot's Avatar
Mine had been like this since new. I have to force myself to slow down when taking it out of 4X4. I back up on a level road. Then I stop completely. Put the transmission in neutral. Let off the brake and turn the 4X4 selector to 2wheel drive. I have had several customers with this same problem and this has always worked.....
Old 11-16-2011, 06:07 PM
farm boy's Avatar
Ok sweet i will try that in the morning and let you know if that works. Thanks for the help
Old 11-16-2011, 07:38 PM
fordornothing's Avatar
IMO, the electric switch is a joke. I don't know what is so hard about reaching down to pull a lever but i guess it's to complicated for most. yes my pickup has it. but it's going away pretty soon. and if it's really cold out, ie. 5* F or lower. it will not engage or disengage. it pretty much locks up the actuator.
Old 11-16-2011, 08:08 PM
CMCA Swartzkrautheim's Avatar
fordornothing do u like ur six speed AND is it just cut the floor pan and swap for ur transfer or are u gonna ad a lever too the electronic t/c? id MUCH rather have a manual t/c
Old 11-16-2011, 08:22 PM
you have to swap the whole t/c and a short wiring harness. There is actually already a hole in the floor pan. it has a cover plate that is screwed down and has the nastiest glue on it. you need a chisel and a BFH to get the plate off.
and i do like my 6 speed.
Quick Reply: 4Wheel drive problem
