White Smoke Rough Idle
Old 12-29-2011, 09:21 AM
mdpursley's Avatar
Default White Smoke Rough Idle
I have a 2000 Ford F250 7.3l Powerstroke and just recently started smoking white at idle and under acceleration. Seems to smoke worse when sitting at a light and then starting to accelerate. Smells like fuel. Runs really rough until about 2000 RPM's then smooths out. I was thinking Fuel Injection Control Module but any help would be great.
Truck has a 5" BRP and I believe a single stage Hypertech (old sticker in door and seems to spool faster than normal)
Old 12-29-2011, 09:36 AM
CSIPSD's Avatar
You dont have a FICM...
You have a PCM, but that would not cause this issue.
Sounds like injector O rings or an injector issue.
I would first stop driving it, and then go ahead and replace the injector O rings.
Once that is done if the issue does not go away then go from there.
Old 12-29-2011, 09:44 AM
mdpursley's Avatar
Thank You very much I will start there and see what happens
Old 01-03-2012, 02:23 PM
mdpursley's Avatar
So got word back on the truck and it dropped a #4 injector. I was thinking upgrade injectors since I have to get in there to do 1. Is this a good idea and what would a good choice be. I will also be looking for turbo advice and a chip. Maybe not all at once since I am not that weathly but any info on which injector and turbo set up would be greatly appreciated.
mattshow123
14
03-12-2018 01:41 PM
coolf250
12-02-2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
10-06-2015 10:54 AM
greenbastard
04-13-2015 08:30 AM
Fishy816
01-11-2015 08:31 AM
Quick Reply: White Smoke Rough Idle
