RPM gauge drop then return
Old 12-30-2011, 05:23 PM
AHOLECEK's Avatar
Default RPM gauge drop then return
While im driving. The RPM gauge will drop for about 15 min and return. Also when I shut the truck off. Somtimes it will not start back up, just turn over. Again I have to wait 15 min or so and then it will start
Old 12-30-2011, 06:19 PM
empty wallet's Avatar
Sounds like crank pos. sensor, but scan for codes or do key trick, cam sensor has same symptom
Old 12-30-2011, 07:35 PM
ajlester's Avatar
2000 models have a cam and a crank sensor. my 2000 reg. cab did the same thing and it turned out to be crank sensor. the ecm on 2000 models uses the crank sensor as the primary sensor for timing and the cam for back-up.
Detroit Tahoe
10-05-2015 05:17 PM
Taylor03
06-06-2015 11:09 AM
InheritedDiesel
04-12-2015 04:35 AM
MrCat4974
Ford Truck and Powerstroke Turbo Diesel Forum
03-23-2015 11:30 PM
99stackedpowerstroke
02-07-2015 10:58 AM
Quick Reply: RPM gauge drop then return
