2002 7.3 shuts off while driving
Old 01-02-2012, 01:59 PM
Jake McFelea's Avatar
Default 2002 7.3 shuts off while driving
I have a 2002 7.3.... Was driving today and the truck shut off, motor stills runs but I have no pedal or gauges. Will start but I still have no pedal or gauges.... Let it sit for a hour and everything was fine for about 30 minutes and it done it again. This time, I cant get and gauges or pedal after 3 hours of sitting.....
Old 01-02-2012, 04:40 PM
fordornothing's Avatar
check fuse No. 19. center row, 8th one down. it's a ten amp. if it blows it again, unplug the fuel bowl heater.
Old 01-02-2012, 05:17 PM
Tried the 19th fuse...it is a 10 amp on the bottom, wasn't blown replaced anyways and still no gauges or pedal when start
I looked up a diagram of my fuse panel under the dash and it doesn't match anything I've seen....
Last edited by Jake McFelea; 01-02-2012 at 05:17 PM. Reason: Automerged Doublepost
are you sure you got the right one. this is going on to my buddies pickup and it blew that fuse. no throttle respose, and no gauges.
Old 01-02-2012, 05:20 PM
I looked on the cover and and matched the 19th fuse to it..... I also checked every fuse, we are talking about the fuse panel under the steering column correct?
Old 01-02-2012, 05:21 PM
yes. do you have any way to pull codes? the fuse is one up from th bottom in the center row.
Old 01-02-2012, 05:25 PM
Ok, that is the correct fuse. The airbag light was flashing a code when I started the truck(has been for awhile) and then staying on. I have no way to get the code though...
Old 01-02-2012, 05:40 PM
and the fuse is ok? did you rplace it any ways? do you know any one with a super chip programmer? a auto zone scanner will not work.
Old 01-02-2012, 05:45 PM
The fuse was fine, I did replace it. I don't know anyone with a programmer, I was told it is a bad shifter or gas pedal??? I bought this truck used and it has had some stuff done to it so no one wants to mess with it. I believe they said it has a TC Tuner on it, I have a **** on the dash to adjust the turbo(I never touch it though). I'm at a loss, never had a diesel til I bought this one 4 months ago.....
Old 01-02-2012, 06:05 PM
TC tuner? turbo adjuster? never heard of those. mybe it has a chip on it... look under the dash at your PCM. if there are wires coming off the back then it has a chip.
Quick Reply: 2002 7.3 shuts off while driving
