Growling noise when clutch let out
Old 01-13-2012, 04:20 PM
billygen's Avatar
Default Growling noise when clutch let out
My stock f 350 make a noise when you first let out on the clutch but after it gets a load on it it goes away.
Old 01-13-2012, 04:21 PM
7.3 Cowboy's Avatar
Like gear rollover noise?
Old 01-14-2012, 02:52 AM
fordornothing's Avatar
Probably. Engine vibrations going into the tranny and shaking the bearings a bit. It's normal.
Old 01-14-2012, 09:21 AM
bowietrucking's Avatar
what clutch? stock clutch shouldn't make any noise like that but both aftermarket clutches i've had made noise when you let the clutch out. kinda like a bearing going out but everyone says its normal..
Old 01-14-2012, 10:04 AM
billygen's Avatar
yes it sounds like a bearing going out, and it is stock clutch, been doing this for a long time, and hasnt gotten any worse, kinda thought it might be a broken clutch spring.
Old 01-14-2012, 01:31 PM
stock clutches do it. they all do it. if it was a broken clutch spring you probably wouldn't have a clutch.
Old 01-14-2012, 02:02 PM
7.3 Cowboy's Avatar
Every 6spd one i know does it
Old 01-14-2012, 02:33 PM
Seydler3's Avatar
Maybe release bearing?
Sent from my Droid
Incredible 2 by HTC via Tapatalk.
Old 01-15-2012, 10:13 AM
no. it's just internal bearings getting rattled a bit. don't worry about it.
Old 01-16-2012, 07:18 AM
billygen's Avatar
Quick Reply: Growling noise when clutch let out
