power loss and turbo whine
Old 01-30-2012, 02:56 PM
rabidrabbit's Avatar
Default power loss and turbo whine
I had high speed (50 mph or >) power loss when accelerating.....it surged or cut out. I replaced the pressure sensor. I now have a whine at turbo spool up. It still surges but its probably less. I rigged a pressure tester and checked for intercooler leaks. Can't find any major leaks just a few small bubbles around one clamp. What could cause turbo whine with high speed power loss. The turbo blades are clean and feel tight...no wobble. Ideas, suggestions appreciated!
Fuel clean, fuel pressure good.
Stock 1999 2 gen 24 valve 5.9 with Fass lift pump.
Old 02-09-2012, 04:03 PM
1cummins01's Avatar
Nothing here?? It seems to me that mine whines as well, but at 22+ on the gauge. I am trying not go get it that high, dont want to have to buy a turbo right now. Other things first.
Old 02-10-2012, 07:18 AM
I checked clearance between the turbo blades and housing....it was .015....within specs I believe. No detectable bearing thrust movement. I'm thinking I don't have a failing turbo. Maybe a crack I haven't found yet. I get plenty of leak past through the valves when pressure testing. When the intercooler is blocked on the intake side no leaks detected. Mmmmm what could be making the whine....
Old 02-12-2012, 11:18 AM
crazycooter's Avatar
even a small leak in the intercooler will result in a neat little whine. consider that at 3000 rpm, your stock engine is pumping around 10,000 cfm. At least that is what the MSHA tag said on mine when I bought it. You can't duplicate that with your little bitty air compressor.
Old 02-12-2012, 06:02 PM
yakdaddy42's Avatar
PSI is PSI whether it be air or water at 2 cfm or 100,000 cmf, so if the turbo is moveing 10,000 cfm at @35 psi boost or you turn off the motor and attach a compressor and pressure check the inter cooler at 35 psi it will have the same pressure.
Timglow546
8
06-03-2015 10:13 PM
RatsMC
05-04-2015 05:25 PM
Bighouse
04-09-2015 06:51 PM
big tan snorkel
15
12-17-2014 05:04 PM
4estlee
10-07-2014 07:47 PM
Quick Reply: power loss and turbo whine
