6.5 turbo diesel lift pump problems
Old 02-03-2012, 09:26 AM
pig farmer pa.'s Avatar
Default 6.5 turbo diesel lift pump problems
need HELP bought this half ton chevy truck has 6.5 turbo diesel in it with 5000 miles this is a new motor w/ new pump.... problem i am having is i replaced lift pump for a day with a 15 psi then got the pump i guess is to be on it and truck just seems like not enough fuel to run it.?? when the 15 psi on it truck ran fine real good but when i went to the one it calls for runs like crap..... i was told the 15 lb pump would damage the injection pump is this true ????? this motor is to be a up graded 6.5 reciept says DS506-AF-C combo 6.5l turbo drop-in engine diesel--4 bolt w/p can anybody help ??????
Old 02-03-2012, 09:28 AM
ebarresi5894's Avatar
no. it wont, if anything it would help the IP.
what year is your truck?
Old 02-03-2012, 09:35 AM
94 1/2 ton
Old 02-03-2012, 09:40 AM
if you get a pump for a 93 you will get the most PSI, if your read some threads they will have more info on it
Old 02-03-2012, 09:41 AM
why does chevy diesel tech say it will ?? never had diesel before really like but for this prob having right now have already been down the P M D road. think i have a spare now cause all the hic-ups i was having thought it was the pmd ended up being lift pump
Old 02-03-2012, 09:45 AM
did you change the OIl Pressure Switch too?
Old 02-03-2012, 09:49 AM
ok thanks i will read down the page to see i was going to put the 15 lb back on but did not want to cost myself 600 to 1000 bucks cause i was stupid
no the guy i bought it from said he just did that before i got it but should do it so i will know myself put new fuel filter in it the new lift pump was to run between 5 to 9 lbs thats when i was told bout the 15lb one hurting my injection pump
Last edited by pig farmer pa.; 02-03-2012 at 09:49 AM. Reason: Automerged Doublepost
Old 02-03-2012, 09:52 AM
when you replace it make sure you do with AC Delco. dont get anyone else, i put one in my white truck and it lasted 2 weeks, the ac delco still works.
"at idle should be around 9 to 12 psi
normal driving 7 to 9 psi
foot to the floor 3.5 to 6 psi"
-Thank Crazy
Last edited by ebarresi5894; 02-03-2012 at 09:52 AM. Reason: Automerged Doublepost
Old 02-03-2012, 10:01 AM
the oil pressure switch you talking bout ??? DO you think it is ok to put 15 lb back in then ?? cause it really ran much better will it hurt injec. pump???
Old 02-03-2012, 10:35 AM
it shouldnt i dont see why it would if anything it is helping the IP because it doesnt have to work as hard
Quick Reply: 6.5 turbo diesel lift pump problems
