Ford Powerstroke 08-10 6.4L Discussion of 6.4 Liter Ford Powerstroke Turbo Diesels
How many miles you have on your 6.4 PSD
Old 02-06-2012, 04:05 PM
gunman41mag's Avatar
Moderator
Default How many miles you have on your 6.4 PSD
I bought my 2008 F-250 brand new on 10/23/2008 & I now have 50,200 miles & i've only has a DPF light warning on the dash, but the next day it went away
Old 02-07-2012, 01:01 PM
chromehound's Avatar
Mines a job 1 with 39xxx but I've only had it for a little over 3 months. Only issues since I've had it: clock spring in the steering column messed up the cruise, torn rubber boot on the steering, lines for what I think run the 4x4 kept popping out of their holders. Of course it's on its 3rd P/S pump since it was new but I haven't had any issues with that *knock on wood* and had something to do with the pass VC fixed before I got it.
Old 02-07-2012, 03:09 PM
Moderator
I have a JOB 2, & when the DPF code lite up, I drove it hard, like I stole it & the code went away
Old 02-07-2012, 06:16 PM
The only time I've had anything DPF related was when I first got the truck and set it back to stock-I forgot the DPF was in my garage and it threw some codes, wiped codes put a canned tune on with DPF off and no more issue.
Old 02-13-2012, 10:53 AM
fletch0467's Avatar
I have a 2008 F-250 Super Duty Ext.Cab XLT 213,000 miles stock. Previous owner was Enterprise Fleet Leasing, went through 6 radiators when they owned it. I am installing Coolant filter kit, CCV mod, DPF/Cat Delete with a tuner...have not made up my mind on tuner ...still looking.
Old 02-13-2012, 01:18 PM
Moderator
WOW !!! That's a lot of miles on a DPF truck I've never had any issues with the radiator your truck must have been built before 8/2007
Old 02-13-2012, 02:35 PM
fletch0467's Avatar
Yes, it was built 3/2007. Still have some concerns about removing stock parts and un leashing it after 213K miles....the tuner trans. re-learn is my BIGGEST worry
Old 02-13-2012, 03:17 PM
Moderator
OK, Those JOB 1 had issues with the radiators, but FORD has a fix for them
Old 02-13-2012, 03:39 PM
fletch0467's Avatar
I checked Oasis report. Last radiator replaced at 171K miles, previous owner had to pay 300.00 deductable, so hopefully it ok now. I am still installing the Coolant Filter Mod. and CCV mod also to go along with the DPF/Cat Delete and Tuner
Old 04-16-2012, 01:47 PM
Moderator
I now have 53, 500 miles on my truck
Quick Reply: How many miles you have on your 6.4 PSD
