Coolant filter kit
Old 04-16-2012, 07:46 PM
jfi's Avatar
jfi
jfi is offline
Default Coolant filter kit
Hey guys, thinking of adding coolant filter kit? which is best one to use and cost??
Also do you need to bleed air out of system after install and what is best way to do that?
Thanks
Old 04-16-2012, 07:50 PM
LORDDiESEL's Avatar
i went with the sinister kit. i just topped it off with coolant and it was good to go.
jfi (04-17-2012)
Old 04-16-2012, 08:07 PM
guzlndzl's Avatar
i just got the same filter kit waiting for it to come in .. have you changed the filter out and cut open to see what its getting if any?
Old 04-17-2012, 05:52 AM
jimrd's Avatar
I bought the Diesel Site Coolant filter Kit
Installation was easy and straight forward
Yes i cut mine open after one year
Then i changed the filter again flushed the system with distilled water and used CAT 1 antifreeze
jfi (04-17-2012)
Old 04-17-2012, 10:20 AM
You went a year on the first one? Don't they say like 1000 miles for the first change? You can tell when they need changing just by feeling the aluminum filter head. If it's really hot, coolant is flowing through it, if it's just warm from heat under the hood and not really hot, nothing is flowing and it needs changing. I use the dieselsite setup too. They're the same thing, just pick which colors you like best.
jfi (04-17-2012)
Old 04-23-2012, 08:56 AM
jimrd's Avatar
i went one year
if you grab a flash light and take the cap of the coolant over flow bottle you can see the coolant go back to the bottle
and the alum filter housing was hot...so i know there is flow
Based on the pics these filters work
thanks
Old 04-23-2012, 09:00 AM
guzlndzl's Avatar
I just installed mine along with egr delete and new oil cooler , all i can say is i hope it works
Cause when i took out the oil cooler that thing was plugged on one side of water inlet
Old 04-23-2012, 10:23 AM
They work very well guys!
I'm amazed you made it a year on that filter, nice! Must have been pretty clean inside. Had you done a flush or anything previous?
Old 04-30-2012, 07:18 AM
jimrd's Avatar
it must have been flushed prior to me owning the truck
I recently installed the oil by pass filter using Amsoil Filter with nu sports kit from California
caissiel
09-24-2015 05:37 PM
Strictly Diesel
Strictly Diesel
09-17-2015 05:11 PM
Bob V
04-06-2015 11:02 PM
97f-250
11-23-2014 08:08 PM
jeffersonl
10-25-2014 06:46 AM
Quick Reply: Coolant filter kit
