2002 7.3 runs and blows blue smoke at high idle first 5 minutes
Old 05-06-2012, 08:40 PM
2012cobra's Avatar
Default 2002 7.3 runs and blows blue smoke at high idle first 5 minutes
When my truck first starts it will only not stall if you floor it for the first 5 minutes and blows out blue smoke and then after it runs and drives normally .
Old 05-07-2012, 05:32 PM
CSIPSD's Avatar
Floor it, as in 3500RPM's or better... Please stop.
What does it do if you dont do the worst thing you could do when you start it?
Old 05-07-2012, 07:32 PM
2012cobra's Avatar
should have said half throttle, also I run the truck every other day.
Old 05-07-2012, 10:28 PM
articfox's Avatar
its not good to do that it puts strain on the motor let it idle and warm up its probably because its not warmed up so it will run odd and like he said dont do that its terrible for your motor.
also try some diesel fuel injector cleaner...
Old 05-14-2012, 09:47 AM
Smokey Freedom's Avatar
Check your blow by. sounds like youre lacking in the ring/compression department. Rings expand when it warms up and closes the tollerences so it quits burning oil/only half burning the fuel. Im betting its motor time.
