How To Make SMOKE And Lots Of It!
Old 02-17-2008, 01:59 AM
ykdave's Avatar
Default How To Make SMOKE And Lots Of It!
Hey guys, got a 97 ram 2500 with the old cummins oil burner...
The truck is just another play toy (definately no daily driver street rig)and i want to get this thing to roll out the smoke. Im not talking a little hoot of smoke when you stomp the loud pedal, im talking about blowing clouds of BLACK smoke that block out the sun for 30min!
Also looking to have a little power behind all that smoke...
I dont think anything looks better than an oil oil burner stopped, spooling the turbo(s) and pouring out clouds of smoke as it takes off like a f'n rocket!
What do you figure is required for such an occasion?
Old 02-17-2008, 02:17 AM
2500HeavyDuty's Avatar
First off welcome to the site
There will be some cummins fellas who will be able to help you out with that pretty soon.
you could take a look at this hopefully this will help out some.
https://www.dieselbombers.com/showth...t=turning+pump
Old 02-17-2008, 04:41 AM
94cummins12v's Avatar
all you really need is a set a fuel plate to get the smoke also to kive it that kick get a set of performance injectors, fuel plate, governor spring and a turbo and you will be set
Old 02-17-2008, 06:41 PM
Monster Truck's Avatar
Throw out the fuel plate and gut the afc and she will smoke. Also make sure it has a good fresh fuel filter in it. I dont suggest doing this without at least a egt guage.
Old 02-17-2008, 08:39 PM
ykdave's Avatar
cranked the starwheel all the way forward and moved the fuel plate about 3/4 of the way forward and it really woke up the truck!
Dont have my gauges on right now so i dont want to slide the plate all the way forward just yet!
Anyone know how much HP a 215 pump would be pushing with the stock plate all the way forward?
Old 02-17-2008, 08:48 PM
if you just purchase a cut fuel plate like a #5 like mine you will boost the power up quite a bit also i just put in my #5 fuel plate friday at 1/4 and it leaves a smoke trail the length of a freeway on-ramp
Old 02-17-2008, 10:35 PM
ykdave's Avatar
Once i get the pyro in ill be grinding the plate myself, why pay a couple hundred bucks for something i can do in 5min and cost nothing?
Anyone know if these things will run pretty hot with the stock plate all the way forward? I want to try sliding it all the way but ill wait for the gauges if its known to be hot like that.
Old 02-17-2008, 10:39 PM
DB Admin's Avatar
Banned
Old 02-18-2008, 12:47 AM
no you wont get that hot with a stock plate
Old 02-18-2008, 12:49 AM
I think that would be a wise move. Why chance it?
BTW, welcome to the site Dave.
Quick Reply: How To Make SMOKE And Lots Of It!
