crank position sensor
Old 06-01-2012, 07:27 PM
tator1991's Avatar
Default crank position sensor
i recently put in a new crank sensor in my 2002 6.6 lb7 and truck no longer runs( it did before but just would die while i was driving and show code ckp) but when i was takin the old one out my nephew tried startin the truck and i got the new sensor in and the truck will not start. Is that because the crank sensor no longer lined up in the correct place with crank shaft. If soo how do u fix it to get it back lined up
Old 06-01-2012, 10:08 PM
2004LB7's Avatar
please list codes. are there any modifications or tuners on the truck?
the crank sensor is self aligning. basically the reluctor wheel has a missing tooth the the ecm uses as the starting point. if the sensor does not send the signal or the ecm doesn't get it the engine wont start.
make sure the sensor is fully seated and no debris between the sensor. check if it will start
if it still wont start then check for any bad wires or shorts with an ohm meter
1997silverado
09-07-2023 06:20 PM
Mr. Walkway
05-11-2015 10:49 AM
robbyS
04-16-2015 02:22 PM
Moly Squid
03-28-2015 04:26 PM
Jmohr52
03-04-2015 01:18 AM
Quick Reply: crank position sensor
