47RE test ports/temp gauge question
Got my Isspro's, and my trans hot line doesn't have the T fitting to screw the sensor into. From my homework here I've found that most people cut the hard line and instal the fitting, or buy a new line with it already there. I reeeeally do not want to do either of these if I don't have to. I've also read that you don't want to instal the fitting in the soft line either, which I wouldn't mind so much but not if it will cause a problem. There are three plugs that I can see in this picture, on the passenger side of the trans just above the pan. Is there any reason why I can't use one of these for the sensor?
I've done both when doing gauges on customer trucks BUT going into a case plug makes the gauge slower to respond compared to being directly in the flow and if your cooler plugs I doubt it will respond fast enough for you to save your trans but then again by that point youre basically shafted anyway. Both work tho
