Dodge Ram Cummins Turbo Diesel Part Out 94' - 02'
I'm currently parting out a 94' and 96' Dodge Ram 2500 Cummins Diesel 4x4 SLT, Regular Cab, Long Bed. ALL PARTS ARE ALREADY PULLED TO SELL.
The Engine, and Body are NOT for sale, and both transmissions have been sold. Most of the bigger parts have been sold as well. AXLES have been sold.
Parts are all the same used in Dodge Rams 94' - 98.5'.
From 98.5' - 02' Some parts have changed and are not exchangeable, but many can still be used up to 02'
**Here is a list of what I have left, and I will remove the items if they sell:**
94' Factory Dodge Cummins Exhaust (Complete from turbo / 3" into 4") - - $80
Front Coil Springs - - $30
Steering Wheel Air Bag - - $75
Steering Column for an Automatic w/ Steering Wheel and Air Bag - - $150
Inside Cab Wire harness - - $50
Automatic Transmission Cooler - - $25
Automatic Transmission Heat Exchanger - - $25
Headliner for a Regular Cab w/ overhead console - - $80
Inside Cab Back Panel with Hooks - - $40
(2) Utility Storage Containers that Attach to the Back Panel Inside the cab - - $30 for both
Interior Panels - - $30
Brake Master Cylinder - - $40
Brake Hard Lines - - $40
Fuel Line from Engine to fuel tank - - $40
35 Gallon Diesel Fuel Tank - - $80
2nd Generation Dodge Ram Rims with Hub Caps (All 4) - - $450
Power Steering Pump - - $50
A/C Receiver/Drier - - $40
Rear View Mirror - - $15
Harmonic Balancer - - $40
NV4500 Flywheel & Pressure Plate - - $80
In tank Pick Up and Fuel Level Sending Unit - - $30
Fuel Lift Pump - - $50
Fuel Bowl and all fuel lines from tank to fuel pump - - $60
Rear Drive Shaft - - $90
Front Drive Shafts - - $60
Upper Radiator Hood Latch Cross Piece - - $30
Transmission Cross Member - - $50
Body Mounts - - $30
Front Rotors from Dana 60 (Need to be turned) - - $25
Body Mounts - - $30
i need the gear box for the power steering pump! asap please
and the brake lines
and the brake lines
looking for driver side door panel, cup holder, maybe power steering pump, sending unit, plastic bumper pieces
will these all work on a 01? and condition of all pieces. My trucks just over 360k
shipped to 17314
thanks!
shipped to 17314
thanks!
Sorry, Selling with the Cab.
I might have one, Ill have to check and make sure!
$150 + Shipping for the Gear Box, and Which brake lines? Hard Lines?
***UPDATE***
NEW ITEMS FOR SALE!!!
96' Cummins 12v Engine with Engine Harness and ECU (170,000 miles and all new seals installed, 60# Valve Spring, 4k Gov and other performance Mods) - - $2,700
Dana 60 Front Axle (3.54 Ring Gear, Open Diff) - - $600
Dana 70 Rear Axle (3.54 Ring Gear, w/ Limited Slip Diff) - - $400
Long Bed w/ Tail Gate - - $550
Hood - - $80
Driver Door - - $150
Passenger Door - - $150
Cab Body w/ all glass - - $350
Seats 40/20/40 - - $150
NV 5600 6 Speed Manual Transmission (Needs Rebuild) - - $1,500
NV 5600 Rebuild Parts! (Rare and hard to find!) (Selling for what I paid, have all paper work) - - $1,400
Set of four 17" Dodge 3rd Gen Rims with 37" BFG All Terrains - - $600
Set of four 16" Dodge 2nd Gen Rims with Hub Caps with factory tire size - - $500
Straight Pipe Exhaust 3" Turbo inlet, 4" Exhaust Pipe with a 5" MBRP Chrome Tip - - $200
Steering Wheel Air Bag - - $80
Steering Column for an Automatic w/ Steering Wheel and Air Bag - - $175
Rear Leaf Spring with All New Polyurethane Bushings - - $125
Upper and Lower Control Arms with New Polyurethane Bushings - - $100
Steering Gear Box - - $175
Thuren Track Bar, 4th Gen Design, Powder Coated, 1k miles on part - - $250
Inside Cab Wire harness - - $75
Headliner for a Regular Cab w/ overhead console - - $75
35 Gallon Diesel Fuel Tank - - $60
35 Gallon Diesel Fuel Tank w/ ISSPRO Ultimate Fuel Level Sending Unit - - $100
Rear Drive Shaft - - $150
Front Drive Shafts - - $75
Upper Radiator Hood Latch Cross Piece - - $40
Bosch Batteries (2) - - $150
Transmission Cross Member - - $60
Body Mounts - - $30
94' Dodge Ram Complete Frame (Regular Cab, Long Bed) - - $400
96' Dodge Ram Complete Frame (Regular Cab, Long Bed) Whole frame is coated with chassis paint inside and out! Rust free! - - $550
***UPDATE***
Hood - - $80
Body Mounts - - $30
David90
09-16-2015 12:48 PM
08-13-2015 11:50 AM
vududady
For Sale
04-15-2015 12:00 AM
10-24-2014 04:40 AM
jstoshick
For Sale
10-02-2014 10:24 PM
