97 ford f350 7.3 how much to replace a bad injector
Old 07-09-2012, 12:14 AM
Powerstroke63's Avatar
Default 97 ford f350 7.3 how much to replace a bad injector
Truck is making a ticking noise and shaking when gasing the truck and lose of power, pretty sure it's an injector, how much to replace and install?
Old 07-09-2012, 03:23 PM
d4klutz's Avatar
It depends if you can do it yourself or not. I dont know if the injector is your problem, but i can find used injectors for about $125 each here in Houston. No guaranty on if they are good or not. Removing the valve cover is a pain, but if you can do it yourself, you will save a bunch of $$. It will take a few hours if you are unfamiliar with the process. If you take it to a shop, a good rule of thumb is "if it goes into the shop, expect to pay around $1000".
Old 07-09-2012, 03:55 PM
1999stroker's Avatar
I replaced glow plugs on my 99 in about 7 hrs but I had a seized glow plug and we ended up removing an injector.it Prolly would of took 4-5 hrs
Sent from my dumb phone!
I have a write up on taking it apart
Old 07-09-2012, 03:58 PM
joebob3093's Avatar
Moderator
how do you know its an injector? did you scan it? did you do any troubleshooting? or are you just guessing?
1997fordf350
01-15-2015 06:12 PM
Quick Reply: 97 ford f350 7.3 how much to replace a bad injector
