6.7 Fuel filter change?
Old 07-16-2012, 07:43 PM
skirk55's Avatar
Default 6.7 Fuel filter change?
I have a 2011 6.7 diesel and it is time to change thefuel filter. Is it hard to do?
Old 07-19-2012, 02:04 PM
Grrrr's Avatar
nope!
Old 07-20-2012, 10:07 PM
Dude_57's Avatar
I'm pretty sure it's just like the old 24 valve get a weather stick the rn of it in the top take lid off pull off old filter and snap one in and put back in I'm doing mine tomorrow
Old 08-09-2012, 10:15 AM
m.wooten's Avatar
do you have to fill the canister with diesel before you screw it back in. I was told you have to but its a pain in the ****.
Old 08-09-2012, 01:31 PM
Grrrr's Avatar
no....its a self priming system. The diesel you pour into the canister is not filtered. Filling it first would allow unfiltered fuel into the engine....
You will just have to crank it a little bit, after you cycle the pump a few times with the key.
Old 08-09-2012, 09:23 PM
m.wooten's Avatar
That makes sense thanks.
Old 08-14-2012, 08:53 PM
07.5 cummins's Avatar
they are diffrent from the 5.9. the whole canister comes off from the bottom and pop the filter out put new in after you reinstall cycle the ignition a few times should prime
Old 08-15-2012, 12:37 AM
cjt8569's Avatar
Nope 11/8 socket and spins right off...
Old 10-02-2012, 03:35 PM
FreeseDiesel's Avatar
depends on your year. some are spin ons, some are 5.9 style. yours being an 11 is a 5.9 style. very very easy. 1 1/8 socket on a breaker bar, do not over tighten, and replace o ring every time.
of course if it was an 08, those are easy too, reach through the fender well cut out.
Old 12-10-2012, 07:52 PM
Farmboy 91's Avatar
I have an 09 6.7 and when I take off in first or second the truck dies so should i change the fuel filter?
jeffersonl
11-15-2015 07:35 PM
RatsMC
05-04-2015 05:25 PM
Collin Dow
02-21-2015 08:18 PM
moneypitk5
02-12-2015 11:01 AM
jeffersonl
10-25-2014 06:46 AM
Quick Reply: 6.7 Fuel filter change?
